Does this unit control charging to the HV battery also??
Where can i order one?
DS3 charging issues
- x 6945
Re: DS3 charging issues
No, the Battery Charge Status Unit has nothing to do with the actual charging of the battery - it's job is to monitor the battery health and inform the BSI of the battery's condition to help the BSI fine-tune the energy management strategy.
If you have a fault on the charging circuit it will be further back - somewhere from the alternator to the battery.
AceB
Are they any DS Automobiles specialist in here??
- x 6945
Hybrid / Electric vehicles are still relatively new and may require specialist advice if you have an issue with the charging circuit.
AceB
Hi Marc I am still having that issue after changing that sensor near the negative battery terminal we towed the car a recharged the battery and it drives great but the 200v charging not working
Radmir
Hi.
Have you solved this issue with the charging? I've got the same issue with ds7 e-tense
