P0238 turbo pressure signal 1.6hdi Peugeot 307
muresan504
Re: P0238 turbo pressure signal 1.6hdi Peugeot 307
Unread post by muresan504 »
I still haven't solved the problem, and it exasperates my brain when the check engine lights up during strong accelerations, overtaking.I assume a gas leak at the exhaust manifold, and I want to replace the gaskets, can the gas leak at the exhaust manifold trigger this fault code?
x 6957
As you've changed the turbo, you should be able to eliminate the last to items of the suspect list, so focus on the vacuum circuit. Check the Turbo control solenoid (39) on the diagram to make sure it is functioning properly and the vacuum pump.
jakestar
New User
Unread post by jakestar »
hi guys, were you able to fix the issue? i seem to have going on the exact same problem… engine light when accelerating with dtc P0238 and i also have a new turbo installed after the old one leaking slightly…
kind of clueluess what to do, thought of changing boost pressure sensor but during diagnosis it seems to catch the correct values… but a weird thing is that during idle the values on the graph are not constant, its a changing pattern of different highs and lows
redordead
Unread post by redordead »
muresan504 wrote: 08 May 2023, 16:43 It's very strange, because it's an intermittent code that only appears during strong acceleration. The car does not go into limp mode. The code is cleared with the diagbox, but it appears again when I accelerate strongly.
??????? ?????? ,???? ????? ??????? ?? 4 ??? ?? ?? ???????? ????? ?????? ??? ??? ? ??? ?? ???? ,?? ??? ?? ???????????? ??????????,?????? ???? 8 ??? ?? ???????? ????? ????????,? ?? ?????? ???? ??? ?? ?????? P0238 ?????? ???????? ?? ???????????????,???? ?????? ?? ??????? ,???? ?????? ?? ????? ,???? ??????? ?????? ?? ?????? ,???? ?? ? ??????????? ???????? ,???? ?????? ? ?????? ?????? ???? 120?? ,????? ???? ????? 40?? ? ???? ????? 80?? ???????? ??????,???? ??.
??????????? ? ?????? ????? 8 ?????? ? ???, ??? ? ???????? ????? 1500??. ????????? ?? ??, ?????????? ?? ??? ? ?????? ? ??? ?????? ???? ?????? ? ?? ???????? ,?? ? ?????? ? ???????? ?? ???????. ??? ???? ???? ??????? ???????? ????.
Translated with DeepL
Hello colleague, I have had the same problem for 4 days, could you share what happened to you and how you solved it, I would be extremely grateful, because in 8 days I have a long trip ahead of me, and I got this error code P0238 high pressure on the turbocharger, no loss of power, no loss of oil, no increased fuel consumption, the error is erased with diagnostics, after driving in one case after 120km, then after about 40km and today about 80km traveled it lights up, it is erased.
The intercooler was replaced 8 months ago with a new one, the DPF was cleaned 1500km ago. The hoses are ok, the EGR cooler was replaced with a new one due to another repair and it was found to be torn in the area of ??the bracket. The EGR was also removed surprisingly clean.
I would be grateful to you or to someone who can help even a little to determine where exactly the problem comes from and whether it is serious.
Thank you very much, stay healthy!
x 5674
Please post in English. You can use Google Translate or DeepL.
redordead
Hello colleague, I have had the same problem for 4 days, could you tell me what happened to you and how you solved it, I will be very grateful because after 8 days I have a long way to go and I got this error code P0238 high turbo pressure no loss of power no loss of oil no increased fuel consumption the error is deleted with diagnostics after driving in one case after 120km then after about 40km and today about 80km traveled it lights up, it is deleted.
Intercooler was replaced 8 months ago with a new one, DPF cleaned 1500km ago. The hoses are fine, the EGR cooler was replaced with a new one due to another repair and it was found to be torn in the bracket area. The EGR was also removed surprisingly cleanly.
I would be grateful if you or anyone could help at least a little to find out where exactly the problem is coming from and if it is serious.
Emrah
Unread post by Emrah »
Iyi aksamlar p0238 ve p1496 bende var 2.0 hdi hbridy eletrovalvo lari degistirdim ve turbo degistirdim dosatoreyi degistirdim coperchio valvoleyi degistirdim halen sorun fortumlari degistirim cozemedim yardim edin tesekurler
x 5674
Translated text:-
"Good evening I have p0238 and p1496 I have 2.0 hdi hbridy eletrovalvos changed and turbo changed, I changed the dosator, I changed the coperchio valvoley, I changed the coperchio valvoley, I still could not solve the problem I changed the forums, please help"
Translated with DeepL. Still some ambiguous terms.
Google Translate:-
"Good evening, I have p0238 and p1496. I changed the 2.0 hdi hybrid eletrovalves and turbo. I changed the dosage. I changed the coperchio valve. I still have a problem. I changed the formulas and couldn't solve it. Please help me. Thanks."
