Please post in English.STAR wrote: 14 Aug 2025, 10:36 Defective engine power station ! (swap coil and change engine centre ) $$$$$$$$
Fault code P1337 coil pack replaced but code still showing
- x 1953
Re: Fault code P1337 coil pack replaced but code still showing
gwest
- x 20
Apart from the gloomy prediction above of ecu replacement, it doesn't take much in the way of air leaks to stop these engines. Check the usual culprits like the turbo air intake and the pcv hoses- their o rings eventually leak. Then start checking all of them.
And you should consider whether your scanner is appropriate. Live data matters.
darbuck
- x 289
This could be as suggested by gwest a vacuum leak or possibly a fueling problem or a plugged exhaust. Can You get fuel trims to help us diagnose it.Doed the exhaust smell fully.
Darren
