Injector coding
Kmarcus
Re: Injector coding
Unread post by Kmarcus »
GiveMeABreak wrote: 18 Feb 2023, 14:00 Have a look at the post here, as these are Fords and alien to me.
viewtopic.php?p=554529#p554529
Which would tie up with the info on this Forum:
https://forscan.org/forum/viewtopic.php?t=2
Also if I have coded them in and diagbox has come up with the message
"Priming of the fuel circuit complete"
And then...
" Replacement of the injectors complete"
Would this indicate the van should now start up? I replaced the injectors due to corrosion broken seals which have all been replaced. I have not started the van up yet incase there is more to do. But do these messages indicate the injectors are now ready? I have no fault codes coming up but haven't tried starting yet.
Cheers.
Kmarcus
Re: Injector coding
Just tried to start it up but it's just turning over. I haven't replaced the fuel filter but surely the injectors are getting fuel or else else they wouldn't be able to complete the injector test?
x 6954
Re: Injector coding
I can only refer you back to my previous post regarding the procedures afterwards:
viewtopic.php?p=744807#p744807
Kmarcus
Re: Injector coding
GiveMeABreak wrote: 19 Feb 2023, 13:40 I can only refer you back to my previous post regarding the procedures afterwards:
Hi again,
I have a fault code referring to the immobiliser not sending the correct code to the ecu. Its code u0426. Could this possibly be the issue?
x 6954
Re: Injector coding
That would certainly do it and result in turn over without starting. I don't have this fault code descriptor but there is a technical bulletin concerning it, so I can't help much there I'm afraid, but the logical thing to do is retrace your steps and check all engine harness connections where you were working.
