Also if I have coded them in and diagbox has come up with the messageGiveMeABreak wrote: 18 Feb 2023, 14:00 Have a look at the post here, as these are Fords and alien to me.
viewtopic.php?p=554529#p554529
Which would tie up with the info on this Forum:
https://forscan.org/forum/viewtopic.php?t=2
"Priming of the fuel circuit complete"
And then...
" Replacement of the injectors complete"
Would this indicate the van should now start up? I replaced the injectors due to corrosion broken seals which have all been replaced. I have not started the van up yet incase there is more to do. But do these messages indicate the injectors are now ready? I have no fault codes coming up but haven't tried starting yet.
Cheers.
