Next time you're under have a look 👀
x 2374
Re: Next time you're under have a look 👀
Unread post by MattBLancs »
Sloppysod: Yes, understand about the bigger diameter, I've no direct experience of the spiral wrap - I assumed it would be possible to wrapped it round something larger diameter (expand the helix so to speak) - but looking again, maybe it's a different product I am thinking of.
Elkc5: Yes, self amalgamating tape is good stuff, again I wonder about its max in service temperature, but worth a shot.
The standard expandable mesh stuff does suggest it was a known issue, but it was ground away like the hose was too.
So I go back to my point earlier - prevention better than cure, so keep heat shield and hose from contact seems the ideal fix :)
x 5689
Will it withstand the temperature though?
Ross_K
x 110
Unread post by Ross_K »
Aluminium "speed tape" maybe?
https://www.amazon.co.uk/3M-1436G50-Alu ... 00TYU2K8M/
I've seen a high temp wrap for use on exhaust manifolds etc but that's probably overkill for this application
https://www.amazon.com/LEDAUT-Titanium- ... 011AYZIW4/
