I was under that impression too, that's why I argued with Citroen in the first place. But they insisted I should wash it.GiveMeABreak wrote: 12 Oct 2022, 22:57 2) On your vehicle the DPF should be replaced at 100k miles officially. The additive should be refilled at 75k miles. Some vehicles then specify a check every so many thousand miles if not topped up and reset, but yours just states to refill it at 75k.
After finding out that the soot levels are at 18% I can't understand why they choose to recommend that at all. I don't think the dpf is causing the warning, the car has no performance issues, so no reason to suspect that it could be a bad reading.
I much more inclined to suspect a sensor or the eolys levels, and since learning that the level is only an approximation, I'll start there. I booked to have it topped off on Monday.
Once have the lexia3 I'll know more and keep this thread updated for future references.
