Windscreen wipers and lights starts to flash when you turn off the car citroen C3 II 2010 1.6 HDI 92 HP
PaulC5
x 665
Re: Windscreen wipers and lights starts to flash when you turn off the car citroen C3 II 2010 1.6 HDI 92 HP
Unread post by PaulC5 »
Whenever there are any odd electrical problems the first check should be the battery voltage, if low apparent problems can appear but once the battery is charged up never occur again. Before starting the engine first thing in the day a fully charged battery will be about 12.7 volts but if below about 12.5 volts it needs charging.
gaskellpaul
Unread post by gaskellpaul »
Anyone have a solution yet? Same thing has just happened to me after a 45 minute drive home, never happened before owned car for 6 years
x 6955
Try a BSI Reset / Battery Disconnect / Reconnect Procedure
However it may be the engine fuse box playing up as both lights and wipers are powered by it.
gaskellpaul
Thanks I'll try the bsinreset tomorrow, been looking at the used fuse boxes on eBay, cheapest I can see is £65
gaskellpaul
Hi I tried the bsi reset and it still happened, if I buy a used fuse box from eBay and do a straight swap is it easy to do as in plug and play or will it need coding, configuring etc? Has anyone done this? Is it difficult to do? Thanks
x 6955
For the C3 (A51), there is no configuration of the engine fuse box, but if you decide to replace it, make sure it is the correct part. I would suggest you have it properly diagnosed first before replacing parts to make sure there isn't another fault causing this.
gaskellpaul
Thanks I have found an identical numbered one on eBay, bam 9667199680
When it's happening you can hear the relay clicking in and out continuously under the fuse box.
c.morewood
x 55
Unread post by c.morewood »
Anyone found a Solution to this yet?
I have an old 2008 mk2 C3. The key fob got wet and threw up an imobiliser fault initially.. After drying put and a new battery.. the immobiliser fault is still there intermittently, but the lights and wipers with no key in the ignition, fault has started.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 6955
This issue is usually associated with the comms unit under the steering wheel.
c.morewood
x 55
Thanks Marc. I was assuming it was salt related as the car sits outside in the salt air every day.
At least the immobiliser fault has cured and disconnecting the battery solves the other fault.. its only got 6 months to live abd will never pass another MOT so not worth spending any money on it apart from diesel and the fob battery.
'94 Fiat TipoTd 40K
x 6955
Ok, understand.
