Identify codes
Lancaster-c5
(Donor 2022)
Re: Identify codes
Unread post by Lancaster-c5 »
Hi ,injectors 3&4 are out they are made by continental .I will see what's on the internet for replacements 🙂
C5 1.6 e-hdi
x 6955
Re: Identify codes
Your injectors are continental, but beware the correct part numbers as they have changed:
Original New replacement part: 9802448680, £542.05
Original Exchange part: 1608518380 £405.85
Doo
(Donor 2022)
x 121
Re: Identify codes
Unread post by Doo »
GiveMeABreak wrote: 28 Jul 2022, 11:54 Your injectors are continental, but beware the correct part numbers as they have changed:
Holy moly! :shock: That's obscene. I wonder if Darwen would be a better price? I know piezo injectors are expensive, but they are taking the mickey.
DD take old injectors and rebuild them in house, supplying recon units off the shelf. I sent my 3rd one in, they called that morning saying they received it and confirming they had one ready to go in the post. I got it two days later (sometimes the post tales two days up here, depending on the time it was posted. However, I know they do next day down south.
I can't speak highly enough of them. Delightful company to deal with :luv:
Has anyone seen the plot? :?
Lancaster-c5
(Donor 2022)
Re: Identify codes
Thanks for the info 👍,yes DD had a better price £170 +vat they arrived today and they have been fitted .I will get them reprogrammed in ASAP.
Does any one know the torque settings for the injector securing bolts 🙂
Many thanks H . DD are very good to deal with very helpfull👍
C5 1.6 e-hdi
Lancaster-c5
(Donor 2022)
Re: Identify codes
DD said they could have reconditioned the continentals but they would need to use an old solenoid on the top of the injector as no new ones are available.
The price would be £30 cheaper but you would always have that niggle of it failing so I went for new ones. 🙂
C5 1.6 e-hdi
Lancaster-c5
(Donor 2022)
Re: Identify codes
Hi I have just found the posts starting from 2013 to 2022 relating to the torque settings
for the injector bolts it’s a long read 😳
C5 1.6 e-hdi
