Expert 2 litre hdi.No com with body comp U1118 and P1693
Taavi-Est
Re: Expert 2 litre hdi.No com with body comp U1118 and P1693
Unread post by Taavi-Est »
Did you erased fault error codes? If codes U1118 and P1693 are active and not erased it wont start either ways. You need diagnostic tool to erase codes.
Also is your car cranking at all? If not then it could be faulty starter, clutch cable or ignition switch.
Mick c
x 4
Unread post by Mick c »
Hi mate , sorry for the late reply. The van cranks over very well and was firing on easy start .
The auto sparks hasn't been yet so I've not been on it . Since I swapped over the bsm the sync between the cam and crank shaft have been inconsistent and I'm not sure if I've disturbed another wire doing this. Thanks again for the replies.
Taavi-Est
Update, i swapped my bsm with my other van and other van still runs fine but the van with problem ran whole day without problem but suddenly it stopped again and now i see crankshaft sensor error P0337 Engine speed signal sc between two wires or oc.
I will check wires and swap sensors i think and see if this is the problem, will let u know soon.
Taavi-Est
I also found error with my bsm/bsi module, my van alternator doesnt start charging unless i rev engine. Seems that alternator gets its signal from bsm module to start charging because if i swapped bsm then other van doest charge battery at idle unless i rev engine once.
Mick c
x 4
Hi 👋 how are you getting on with your motor ?.
I've had a break from.mine but having another go today . Removing intake manifold to change leak back pipes , check cam sensor pick up and fit replacement hp pump . Hoping for a result 🙏
Mick c
x 4
Ok update ! Removed pump and it's had it ! Turns by hand with ease. The drive cog on the end is worn and damaged. Can't see the end of the cam shaft a dual don't know what it should look like tbh . Funny how it was all running before the injectors were changed ?. Has anyone got a picture of the 2.0hdi camshaft in head to see what I should be looking at please 🙏. Tia
Mick c
x 4
So exhausted cam has had it and no way of knowing where the bits have gone ?. Has anyone ever had this ? . Replaced exhaust cam and been ok 👍
Taavi-Est
Hi i made a break myself too, car is not working at all right now, seems to be some wiring or ecu fault.
Now i have errors:
P1352
P1197
P1694
0117
Ill check mass cables, it might be this.
Did you get your engine to work?
