DS5 Electronic engine Immobiliser fault
liquidhandwash
x 22
Re: DS5 Electronic engine Immobiliser fault
Unread post by liquidhandwash »
Edson Achaca wrote: 12 Nov 2022, 21:51 I have a 2012 Citroën DS5 that is at one of Citroën dealership in South Africa and they said there is a problem with my electronic immobiliser and the part number is 9815905380 but they don’t have stock in the country and the ETA 23/01/2023 can anyone help me find this part? I can’t find it online.
Ive used HDi tuning they can supply an ECU with the immobiliser deleted.
https://hdi-tuning.co.uk/unlocked-ecus/
Edson Achaca
Unread post by Edson Achaca »
Cool thanks
x 6945
Ok, that part is for the actual electronic steering lock to be more precise - which is one of the parts I mentioned in my last post.
Unfortunately, you won't have much luck even if you managed to buy one yourself as it needs initialising with the correct diagnostic equipment after fitting.
Edson Achaca
Yes I know I just wanted to know which part it’s so I can try buy online and take to the Citroën dealership because through them I can only get the part on 23/01/2023. Do you know where can I buy it online?
x 6945
liquidhandwash wrote: 12 Nov 2022, 23:02
That won't work - this is not an engine ECU, it's an electronic steering lock
x 6945
Edson Achaca wrote: 13 Nov 2022, 22:51 Yes I know I just wanted to know which part it’s so I can try buy online and take to the Citroën dealership because through them I can only get the part on 23/01/2023. Do you know where can I buy it online?
Just 'Google' your part number, there are lots of results.
Edson Achaca
Me too
