That is all correct....
30 and 87 are the main switching contacts, which connect when the relay is energised
85 and 86 are the coil connections
Xantia Headlight Bulbs
admiral51
- (Donor 2026)
- x 391
Re: Xantia Headlight Bulbs
Just a quick update.
The good lady has now been unable to work due to Covid restrictions so i have the C5 as a daily driver so this issue will be sorted but at the moment it is not as urgent as it was and i will post updates on the results.
- x 3306
Well, I would make a start on the mod anyway. As the Xantia is not needed at this time you can take your time to do the job properly, and not worry about having off the road when you need her.
admiral51
- (Donor 2026)
- x 391
James that is the intention but the Good Lady is part of the Bubble for my elderly parents and cannot afford not to have a car available if i end doing what i normally do with electrics and leave it unusable and half started and half finished
