For a stuck pressure plate
- press down on the clutch
- put into gear, parking brake firmly on
- operate the starter
Should separate adhesion between flywheel/clutch cover and the friction plate, as both flywheel and clutch cover will rotate, but friction plate will remain stationary.
Not using car for longer period
- x 1746
Re: Not using car for longer period
That's what I was referring to earlier, the result sometimes was to rip the linings off the centre plate or tear the hub out.
Skull
- (Donor 2026)
- x 382
Cheers Paul
It was 1990 .....and I can't remember what else I tried but after the clutch pipe burst I obviously couldn't apply any pressure to the clutch
Proper money pit that TR7
Gary
Gary
