Berlingo 2011 Horn not working - relay ?
RoadRunner24
Re: Berlingo 2011 Horn not working - relay ?
Unread post by RoadRunner24 »
Hiya, no feed at the horn
x 1055
Unread post by wheeler »
Have you checked all the fuses?
RoadRunner24
Yep
x 1240
Unread post by Peter.N. »
I had something like this happen to the radio in my C5 and it turned out to be a fault on the BSI. Rather than risk immobilising the car I fitted and aftermarket radio and satnav. Shouldn't be to difficult to find the horn push lead and run it to a relay to feed the horn.
RoadRunner24
I think bypassing the BSI is my way forward. Am I right in saying it should have a live at the horn and earth's through pushing the horn?
x 1240
I think the horn button goes to earth when used, in which case you will need live to the horn but I would check on that. As it commands the ECU I doubt it has 12v on it.. It shouldn't be to difficult to earth one side of it anyway. You will probably need a relay in the circuit as the current demand may exceed to rating of the contacts on the push.
Or you could wire a bell push or similar in.
RoadRunner24
Turns out to be the horn itself. Fixed now. Thanks anyhow๐Ÿ™‚๐Ÿ‘๐Ÿป
x 1055
RoadRunner24 wrote: 11 Sep 2024, 18:28 Turns out to be the horn itself. Fixed now. Thanks anyhow๐Ÿ™‚๐Ÿ‘๐Ÿป
RoadRunner24 wrote: 10 Sep 2024, 19:34 Hiya, no feed at the horn
I thought there was no feed at the horn ??
RoadRunner24
wheeler wrote: 11 Sep 2024, 19:49
There didn't seem to be but the new horn is working ๐Ÿ˜
x 1240
The indicators on my 406 did that!
