2001 Berlingo seats
Flogeot
Re: 2001 Berlingo seats
Unread post by Flogeot »
I put Peugeot 306 chairs in. The driver seat is basically same and bolted onto the base frame easily. It is little higher than the original seat so might add a 1cm spacer at the back of the floor frame later. For the passengers seat I replaced the foam cushions and upholstery so the seat still folds over twice. Only missed the front bracket for holding the upholstery tight, but fixed that by driliing two holes in the chair frame and placed the 306 bracket into that. Great improvement!
Flogeot
I swapped cushions from (think) 306, with a bit of creativity it was few hours work. Much better! Because of the different seating position I added a 2cm spacer at the back of the rails. Even the foldable passenger seat still functions.
