I advice again please! Gearbox oil
David_M
Re: I advice again please! Gearbox oil
Unread post by David_M »
PaulC5 wrote: 12 Mar 2025, 13:59 Post your vin and admin may be able to look up your car.
Thanks - My VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
OH and - it WRONGLY states that this is an AUTO on the V5, but it's most definitely a 5 speed manual! (Weird !?)
xantia_v6 wrote: 13 Mar 2025, 00:45 There is I think a level plug on the rear of the transmission, if you want to check the level.
Overfilling is not a great idea.
Thankyou, I will try & locate this level.plug to check, thanks so much for your reply at such an hour! 😄👍
wurlycorner
x 271
Unread post by wurlycorner »
David_M wrote: 13 Mar 2025, 00:38 Thankyou Iain,
Edit: Just noticed you mentioned ML6C.in your reply, on further research, this is the 6 speed box? Mine is a "5 speed" hence I think I have the ML5C box!
It would be, yes. Without the reg number I could only lookup based just on the car model info in your post/profile and that gearbox is what came up - thought it was interesting that the two options seemed to match exactly your experience of what you thought it should take v what you drained out!
I guess it's possible having drained that much out, suggests it was overfilled by a previous mechanic who looked up somewhere and thought it was an ML6C without cooling fins :-)
Iain
CX DTR T2 Safari (silver)
