Power steering question
- x 6950
Re: Power steering question
Ok, so if you have the VIN for that vehicle, pop it up for me and I'll have a check for you.
- x 1061
It looks like it does indeed share the same system as the early C3's, the only electrical part listed separately is the power steering ECU, These are generally pretty reliable though.Jay-Bruce wrote: 09 Apr 2022, 15:16 I've also got a Peugeot 1007 that I look after, which I believe uses the same system as this? And it's got an issue whereby it's gotfeather light steering one direction, and only light, rather than feather light steering the other direction. Having had a play with it a while ago I found that on full lock right its' recording 11.1nm torque, full lock to the left shows 8.9nm torque and rest is 1.1nm torque to the right. So that's why I'm asking about the torque sensor, I'd rather reset or replace the sensor than buy a used or refurbished rack.
There are companies out there (like BBA reman) that will refurb or repair these.
