C5 Tourer 2008 V6 HDi Suspension fault
chris_reade
Re: C5 Tourer 2008 V6 HDi Suspension fault
All fixed, just the fuse under the ecu. Thanks for all help, I have been in hospital for a week, hence the silence. Before that I found an independent Mechanic with a lexia just round the corner. The lexia showed no faults, so after a 2 day investigation he found the maxi fuses under the ecu. All seems fine, no leaks, if I ever find why the fuse blew I'll let you know. Cheers, Chris ps he only charged me 60€ to sort it!
- x 2001
This problem is often due to a build up of dust/brush residue inside the pump............
chris_reade
Right, will keep an eye on that! Thanks again.
- x 6957
Great, thanks for updating us - always good to get the end result and cause!
