No, maybe Citroen didn't but I know of a 04 plate 407 with the 16v engine in it Paul...
Paired up with a lovely 4HP20 I rebuilt when it had covered well over 200K...
Pug Problems
- x 8386
Re: Pug Problems
citroenxm
- Fallen Hero
- x 70
Re: Pug Problems
Lol.. AL4 AL4 AL4 AL4... lol..
I know someone who isnt impressed with a hp20 that lasted just 30k... so out with the rubbish in with a proper manual box.. lol
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Planko87
Re: Pug Problems
She's the 16v guys
Sent from my A0001 using Tapatalk
- x 8386
Re: Pug Problems
Love to know what happened to that HP20 Paul as 30K is a very low mileage. Was that after a refurb? OP - sorry for the short hijack... It often happens on herecitroenxm wrote:Lol.. AL4 AL4 AL4 AL4... lol..
citroenxm
- Fallen Hero
- x 70
Re: Pug Problems
I think the previous owner prior to its current one did a bodge job and when it was put is possibly a second hand box and also never had a fluid change due to the dry diff or sealed diff if you like.
I noticed a bolt missing on the engine mount.. and theres the flywheel plate issue catching the block. All very strange.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8386
Re: Pug Problems
Ahh, there you go. Absolutely no bodging allowed on an HP20 under any circumstances... I want to talk further about it Paul but not in this thread and not now.. We'll catch up at some point and have a good natter about it...citroenxm wrote:I think the previous owner prior to its current one did a bodge job and when it was put is possibly a second hand box and also never had a fluid change due to the dry diff or sealed diff if you like.
citroenxm
- Fallen Hero
- x 70
Re: Pug Problems
Not a problem jim.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Planko87
Re: Pug Problems
Post has been well hijacked...
- x 8386
Re: Pug Problems
Sorry. It happens on here. All part of the FCF culture...Planko87 wrote:Post has been well hijacked...
elma
- x 284
Re: Pug Problems
I don't know you're engine at all but our work pickup did the same recently. Cured mostly by fitting a new turbo pipe then completely with a fuel filter. Is the car recently serviced? I'd be inclined to spend £10 on a fuel filter before looking for a fault.
Planko87
Re: Pug Problems
Another 400 mile done and same again. Hearing quite a loud whistle from the turbo than I'm pretty sure wasn't there before. Never owned a car with a turbo so not sure if it's my paranoia or if there's an issue there.
Anyone know of common symptoms of the 2.0 Hdi turbo failing?
- x 8386
Re: Pug Problems
My turbo whistles quite well and it's nothing to worry about... I'd suspect yours is nothing to worry about either... Often a whistle may point to a boost leak but generally on late 'clever' diesels like yours even the smallest boost leak will kill performance and raise a fault code in the ECU...
It may be worth having your car diagnosed on Peugeot Planet and seeing if any boost related faults are recorded.. If all clear there's nothing to worry about...
elma
- x 284
Re: Pug Problems
Is it still losing power? Whistling is normal, you'll grow to like it as the boost grows with the whistle. Losing power at the same time is very abnormal and will have an underlying issue.
Planko87
Re: Pug Problems
If you look back through the post I described the power loss. It's very intermittent and 'spluttery' for want of a better word
elma
- x 284
Re: Pug Problems
Unfortunately outside of my expertise. I never buy diesels with any more tech than a cat on them. If you haven't managed a Lexia/Planet session yet it's usually a good starting point with the more modern engines.
