Synergie loose spring in engine bay
Richard_C
(Donor 2026)
x 225
Re: Synergie loose spring in engine bay
Unread post by Richard_C »
We got our Synergie 1.9TD brand new in 1998 (still got it). I think the first service/check was at 1000 miles in those days. I complained that the RPM stayed high for too long when you took your foot off the pedal, mechanic said ah - its the damper, they all do that, we take them off. So he did, so I've never even seen one, thanks for the photo :-).
(Without the damper, if you are trundling along slowly in 1st or 2nd and take your foot off the pedal it lurches a bit, so I can see why they fitted them)
Richard_C
chinkostu
x 30
Unread post by chinkostu »
Mine does exactly that rich! Have to keep an eye on the revs as it will just kangaroo!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1751
How come 1.9TD's never used to do this, and now they do?
ken newbold
x 4
Unread post by ken newbold »
I now have one with and one without, can't say I've noticed any difference :-/
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
chinkostu
x 30
white exec wrote:How come 1.9TD's never used to do this, and now they do?
there is also a little random damper that sits behind the pump, seems to dampen the return to idle and mine doesnt work anymore. wether its related or not i won't know!
it only ever seems to be if i'm using very little throttle at all (just above idle) so maybe it's something to do with the pump?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
elma
x 287
Unread post by elma »
My first xantia came with the damper. I thought it was dangerous as the last 1000 revs fell slowly and it felt similar to braking with a foot lightly on the accelerator. After removing it the car would bounce a little at the front if I took my foot off the accelerator to rapidly. I've only ever had xud9 xantias and no other with the damper. Everyone of them has done the little bounce if I back off the throttle too fast. It's not just a xantia thing as my xud9 Ldv and my 306s did it too.
x 1751
Seems an extraordinary thing to have to put up with.
Wonder exactly when this became an issue on the XUD?
elma
x 287
I don't really think it's so different to any engine. Take your foot off the accelerator quickly and they all bounce a bit, do it smoothly and they don't. I think it's the movement in the engine mounts causing the sensation. With the xud being relatively heavy maybe it's a bigger force change and hence more noticeable.
x 1751
Bigger lump will resist movement more (inertia), but - you are right - it'll thump when it does!
Had BX19RD and XM2.5 both develop excessive fore-aft engine movement, which was cured on the 2.5 by a new lower engine mount (under warranty) and on the BX by simply shimming under the rubber pyramid by 3mm or so.
All movement and 'bounce' promptly disappeared in both cases.
