Mistaken polarity jumpstart AAARGH Help?
x 8437
Re: Mistaken polarity jumpstart AAARGH Help?
c.morewood wrote:only tricky thing is getting the locking pin into the tensioner hole :-)
Yes, that's true..
Just replaced the tensioner on Robyn's 207. Same sort of tensioner but the pin is about 5mm in diameter and a bit easier to get in and out due to it being that much meatier... Same double spanner trick needed to do it though...
neil123
Unread post by neil123 »
Ok, bit confused here...!
The guy who did mine didn't use a pin, as far as I'm aware - he just moved tensioner back with the spanner/tool, looped belt off pulleys, released tension, did the alternator, used tool again to move back tensioner, put belt back on pulleys, release... good to go?
Why do you need the pin - or should I anticipate some disaster about to happen as he didn't?
x 8437
The pin just locks the tensioner back into the fully retracted position and that makes it easy to fit the belt.. Otherwise you need one hand on the long spanners to hold the tensioner retracted whilst you use your remaining hand to fit the belt; a bit like juggling under tension :lol:
neil123
Ah, that explains why he said 'just stick the belt back on while I keep the tension off' then!
He replaced the pin, in effect while I put the belt back on the pulleys!
Good stuff. Thanks all.
rory_perrett
Unread post by rory_perrett »
neil123 wrote:
Thirty five quid labour - and an entertaining hour watching someone else work -
Cheaper than watching some football matches according to reports last week!! :-D The question is which is more entertaining?
x 2006
Unread post by Stickyfinger »
Tis true with Liverpool :).....£300 would be good value to watch the mighty ARSENAL !
x 3298
How much does Leicester charge for their home games?
x 2006
They are playing some very fine and entertaining football that is for sure (this season). Their dissection of Man City was superb.
