Mistaken polarity jumpstart AAARGH Help?
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6156
Contact:
Re: Mistaken polarity jumpstart AAARGH Help?
Post by CitroJim »
c.morewood wrote:only tricky thing is getting the locking pin into the tensioner hole :-)
Yes, that's true..
Just replaced the tensioner on Robyn's 207. Same sort of tensioner but the pin is about 5mm in diameter and a bit easier to get in and out due to it being that much meatier... Same double spanner trick needed to do it though...
Runner, cyclist, time triallist, duathlete, Citroen AX fan and the CCC Citroenian 'From A to Z' Columnist...
neil123
My Cars: 2001 Xantia 110 Hdi Forte estate - owned from new.
1984 2cv Special
Various modern crap!
Post by neil123 »
Ok, bit confused here...!
The guy who did mine didn't use a pin, as far as I'm aware - he just moved tensioner back with the spanner/tool, looped belt off pulleys, released tension, did the alternator, used tool again to move back tensioner, put belt back on pulleys, release... good to go?
Why do you need the pin - or should I anticipate some disaster about to happen as he didn't?
x 6156
Contact:
Post by CitroJim »
The pin just locks the tensioner back into the fully retracted position and that makes it easy to fit the belt.. Otherwise you need one hand on the long spanners to hold the tensioner retracted whilst you use your remaining hand to fit the belt; a bit like juggling under tension :lol:
neil123
1984 2cv Special
Post by neil123 »
Ah, that explains why he said 'just stick the belt back on while I keep the tension off' then!
He replaced the pin, in effect while I put the belt back on the pulleys!
Good stuff. Thanks all.
rory_perrett
My Cars: Xantia Exclusive 110Hdi Estate 1999
Post by rory_perrett »
neil123 wrote:
Thirty five quid labour - and an entertaining hour watching someone else work -
Cheaper than watching some football matches according to reports last week!! :-D The question is which is more entertaining?
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1280
Contact:
Post by Stickyfinger »
Tis true with Liverpool :).....£300 would be good value to watch the mighty ARSENAL !
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 2993
Post by Hell Razor5543 »
How much does Leicester charge for their home games?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
AX, little Daffodil
x 1280
Contact:
They are playing some very fine and entertaining football that is for sure (this season). Their dissection of Man City was superb.
Post Reply
