Brake Pads.
harryp
(Donor 2022)
x 73
Re: Brake Pads.
Unread post by harryp »
Just a thought... Who supplies Citroen with their pads? Cannot envisage them making their own.
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
vborovic
Locked user account
x 40
Re: Brake Pads.
Unread post by vborovic »
I do believe that the genuine Citroen brake pads are actually TRW ...
harryp
(Donor 2022)
x 73
Re: Brake Pads.
Good info vbrovic! They have good reports on here and I guess all "top" marques would be good, having used many of the brands mentioned over many many years! Quite a worry isn't it as the only means of stopping/slowing quickly - brick walls not included. Tyres come in the same category as the contact patch is small and the only thing between you and the road and even more important in the mix assuming the brake rotors can be stopped!!
Regards, Harry
lexi
x 133
Re: Brake Pads.
Unread post by lexi »
Some Citroen pads are made by Bosch. Calipers too. All different for various models and caliper types.
You might not always be able to buy the exact spec that was called for by Citroen. That can be the case across many gen Citroen parts.
In general, aftermarket parts are only required to last for the minimum warranty period. Parts on a new car last a lot longer that that.
Batteries are a case in point. I always find the battery that is supplied new with the car, is the longest lasting.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
qprdude
x 14
Re: Brake Pads.
Unread post by qprdude »
I found that with the battery too. Original lasted over 5 years. Replacement is dropping into economy mode very quickly after just two years. Must get it on the trickle charger overnight.
Rick.
2013 Citroen DS 5 D/Sport
