Xantia Radio Driving Me Mad
x 1454
Re: Xantia Radio Driving Me Mad
Unread post by xantia_v6 »
tim leech wrote:cheers chaps, I will change the radio mast, base and check the connection under the seat.
I could retrofit a modern unit but I like the factory look and tbh its a good piece of kit which my ipod connects straight into.
You just need to take Jim's V6, then you will have all the spares you need :-D
I don't think that the antenna cable goes near the seat, IIRC, it just runs from the pillar around the footwell, also I don't think those radios work so well if you replace the antenna base with one lacking the preamplifier.
And as I said before, a poor signal will not cause the radio to change station, so I think you are wasting your time with the antenna.
I can't remember whether the radio will still run if you unplug the connector at the back of the radio which carries the steering wheel controls, if so, that would be a useful test.
Eddie Nuff
New User
x 38
Unread post by Eddie Nuff »
My solution. Take the car down to the local electronics guy working out of the back of a knackered old van, in the middle of all the wide boy car dealers. Within an hour radio out, problem solved, unit refurbed and back in. £20 for your trouble. Works for me everytime.
x 2000
Re:
Unread post by Stickyfinger »
Eddie Nuff wrote:My solution. Take the car down to the local electronics guy working out of the back of a knackered old van, in the middle of all the wide boy car dealers. Within an hour radio out, problem solved, unit refurbed and back in. £20 for your trouble. Works for me everytime.
If you like "ScotchBlocks", if not offer an extra £10 upfront for soldered joints, its a good plan as these guys can "sort" most things :)
Eddie Nuff
New User
x 38
Nope, all soldered joints, all done properly. That's why he's so busy. (though to look at his van you would never know :wink: )
x 2000
drat I pay to much....I need to find one with a more tatty van :)
