So, do the self adjusters operate from movement of the brake pedal? or the operation of the handbrake cables...
I seem to recall maybe from a Renault 14? that the handbrake NEEDS some travel, for there to be enough operation of the adjusters, too little and they wont self adjust?
Bob
edit just noticed the heading............Xantia..........I am referring to a Xsara Picasso
Xantia handbrake adjustment
chinkostu
- x 30
Re: Xantia handbrake adjustment
think the xsara has a traditional handbrake arrangement so they adjust from the lever, even the disc ones. the best thing to do is get the auto adjusters wound with the handbrake on one click so that the shoes are just starting to drag. if its the disc rear brakes then loading the rear and using the brake should bring the pads to the right spot, usually needs little adjustmentold-un77 wrote:So, do the self adjusters operate from movement of the brake pedal? or the operation of the handbrake cables...
Bob
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
old-un77
I've just had the car serviced and as one of the rear (drum brakes) cylinders was wet under the dust cover he changed both cylinders, commenting that the self adjuster didn't appear to be working.
since the previous service( done by a different garage) the handbrake only needed two clicks to be full on............was wondering if there needed to be some slack to allow the self adjusters to operate..........
Old-Guy
- x 24
Ooops, don't remember including handbrake adjustment in the Brakes wiki.Stickyfinger wrote:With mine (done after seals/disk/pad change), I took off the cable ends off the caliper arms, pressed twice, backed off the cable adjusters all the way and cleaned the threads, then adjusted the cables to the correct amount (just loose) on the arms.
[EDIT] I did but only in passing - now corrected.
