Auxiliary Heater testing Fuel Burning Heater
x 8415
Re: Auxiliary Heater testing Fuel Burning Heater
The one on the HDi Xantia has no internal pump Will, it relies on the engine water pump for circulation...
Some do have pumps but not the Xantia ones...
KP
x 27
Unread post by KP »
Ahh dang, that's that idea out the window then :(
x 8415
KP wrote:Ahh dang, that's that idea out the window then :(
Not necessarily as you can get suitable outboard pumps I'm sure... There are electric water pumps for use with engines.. Often used where they run without a fan belt and the original water pump is fan belt driven. Saves a bit of BHP loss allegedly...
Popular with racing BMC A series engines and the like...
KP
x 27
Unread post by KP »
Just adds more complexity to what was a simpler idea though Jim :(
Never mind eh :)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Are you planning an "off car" installation?
Heated water bed? :P
KP
x 27
Unread post by KP »
Ha ha!!
Nah nothing like that Adam.
Was thinking that if it had a built in pump then remote start units are very cheap now so its a possible mod for people and could be fired up 10minutes before they need to leave and thus they get to a nice warm vehicle and better for the engine as well :D Good for our norsk friends so they don't need block heaters and such :D
h2ocooler
Unread post by h2ocooler »
I have forced the one on my C8 to run with Lexia, I went into the heater and selected actuator tests and it was in there.
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
KP
x 27
Unread post by KP »
Was the engine running at the time H2?
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
KP wrote:But if it has a pump Jim is that not circulating or is the pump on a different circuit?
When you mentioned pump I took it you were talking about a fuel rather than water pump :lol: #-o anyway if you want to fit an auxiliary water pump then look at E39 BMW's and in particular 530i as they have them fitted as standard just behind the radiator.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
KP
x 27
Unread post by KP »
Yeah the petrol and diesel ones are slightly different but there are so many fitted to JLR products with the pump and bits already on for remote firing :)
Ah well, when I get the car back I'll test it and leave it to idle for a bit so as to keep the engine cold and maybe have a hose running cold water over the block to keep it cold and the fbh should stay fired up then :D
h2ocooler
KP wrote:Was the engine running at the time H2?
I really cant remember but think it was, do remember pressing the test and then groping on the floor seeing it light and produce heat.
