Xantia rear brake callipers
elma
x 284
Re: Xantia rear brake callipers
Unread post by elma »
Thats quite interesting.
Mine look different now I look closely, when the bleed nipple fitted the other side I thought it was ok.
Thanks, I would've got them all painted before I found out.
I'll be checking first now I think.
Better take the ones off the car and see what they are like.
They looked rusty and Bindy on first inspection.
I'll put some pics of the car on another thread next week.
I'll be vanishing for 4 days now and back home Saturday to start work on the Xantia.
I'm needing to put it on the road on the 2nd of next month so It'll be getting a lot done quite fast.
x 94
Unread post by citronut »
Mandrake wrote: I'm assuming that the diameter and finish of that inner hole is very critical to get a good high pressure seal (most of the sealing is actually metal to metal at the tip of the pipe not at the rubber seal) so during manufacture they probably drill out a rough slightly smaller hole first, then use another slightly bigger bit as a precision finisher - and not bother to finish the bleed valve side to save a few seconds during machining...
i would have thought if this were the case, they would finish both caliper halves to the same degree, as the half calipers are just switch over from O/S to N/S fitting/usage,
this way the factory just churns out two different half calipers that are mix and matched dependent on which side of the car they are being used at
Regards, malcolm.
c.morewood
x 55
Unread post by c.morewood »
It was suggested on one of the threads last year to use greaseproof paper as a gasket. It works well on my Xantia.. the rears still spin freely 9 months on . no sign of corrosion yet.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 8407
c.morewood wrote:It was suggested on one of the threads last year to use greaseproof paper as a gasket.
That's a good idea Chris. Baking parchment may be even better as it's silicone coated...
Stewart(oily)
x 35
Unread post by Stewart(oily) »
I made my gasket out of visqueen plastic, over a year now and still perfect, I have always copiously lubricated the through bolts with a mixture of oil and grease and never had a problem, lashings of loctite seems to have come along with the C5, BXs seemed to always be greased.
