Hydraulic pressure regulator link below
http://www.frenchcarforum.co.uk/forum/v ... or#p367638" onclick="window.open(this.href);return false;
Xantia plumbing
KennyW
- x 165
Re: Xantia plumbing
C3 1.4 petrol (SWMBO)
KennyW
- x 165
Re: Xantia plumbing
Anti sink sphere
http://www.frenchcarforum.co.uk/forum/v ... 71#p409171" onclick="window.open(this.href);return false;
What started this link in the first place
KennyW
- x 165
Re: Xantia plumbing
Rear LHM leak
http://www.frenchcarforum.co.uk/forum/v ... 84#p361100" onclick="window.open(this.href);return false;
KennyW
- x 165
Re: Xantia plumbing
Rear cylinders
http://www.frenchcarforum.co.uk/forum/v ... 11&t=44218" onclick="window.open(this.href);return false;
KennyW
- x 165
Re: Xantia plumbing
Dowty seals read in conjunction with above link
http://www.frenchcarforum.co.uk/forum/v ... 31#p385339" onclick="window.open(this.href);return false;
KennyW
- x 165
Re: Xantia plumbing
Odd pipe unions
http://www.frenchcarforum.co.uk/forum/v ... 95#p387265" onclick="window.open(this.href);return false;
harryp
- x 75
Re: Xantia plumbing
If I can add to this post...
Have a chafed through pipe on the Exclusive, looks to be similar on the Forte too. Pipe comes off top of the accumulator, down towards left, up through the gearbox mounting clip and onto 3 spirals then up along the near-side engine bay, then travels towards the rear . Any one know the part number, where it goes to, or does Paul have one
It has gone right on the apex of the bend just before the gearbox bracket where it turns up towards the the spirals. Would seem easiest way may be to splice a new piece in, or is it prone to problems further down it''s run; but then I would need to flare it - or are compression joiners available????
Thanks and regards, Harry
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
KennyW
- x 165
Re: Xantia plumbing
Harry
Have you got your chassis number and I'll find it through that.
Kenny
Kenny
KennyW
- x 165
Re: Xantia plumbing
Xantia 10 minute mod
http://www.frenchcarforum.co.uk/forum/v ... on#p410139" onclick="window.open(this.href);return false;
xantos
- x 10
Re: Xantia plumbing
Xantia octopus / LHM reservoir mod
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
c.morewood
- x 55
Re: Xantia plumbing
Here's a link to an associated subject. Height corrector cleaning. https://www.frenchcarforum.co.uk/forum/ ... 19&t=27122
Always best done when replacing pipes. But can it be done with the car on its wheels rather than axle stands.
I've bought a couple of car ramps with lifts on them which will raise one end of the car to a decent height even when depressurised. I can't see any reason why I'd have to use axle stands, unless you know different.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
c.morewood
- x 55
Re: Xantia plumbing Great News.
You don't have to remove the rear cylinder to fit a dowty seal. I've just done it in about 2 hrs using a multi tool. Instructions are on the "dowty seals work" thread viewtopic.php?f=3&t=46231&start=15#p570522
And just done a second one in 1hr 15 min from wheels down to wheels down.
Reason: Added link
Reason: Added link
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
