How much LHM in my Xantia
ekjdm14
x 281
Re: How much LHM in my Xantia
Unread post by ekjdm14 »
Or perhaps you could pop the float out as described (it's on a bayonet fitting a bit like a lightbulb, twist it anti-clockwise and lift out carefully) and investigate why it may have stuck. It's quite possible it just needs a clean I think.
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'87 Nissan Sunny 1.3L, 63k
'12 Mini freebie project
x 1486
Unread post by xantia_v6 »
As has been said earlier in this topic, it would be very unusual for the LHM level indicator to fail.
From the symptoms you describe, I think it is more likely that the pump is sucking in air through a hole in the hose from the LHM tank to the pump. It could just be a loose joint at either end, or it could be a crack in the plastic fitting at the top of the tank.
