[url= 1.9 TD Aux Belt
Hi Ed,
Of the two brackets I've sent you, those tensioners are by no means new! Both have done at least 100k. I don't recall them leaning in any way but then I wasn't really looking. I suspect you can guage play by having a wiggle.
Oh wait, you bought a new one didn't you?
Damn, I could of pressed that tube out for you mate, although hopefully your mate with the workshop can press that out for you. I have to say Ed that I don't know an awful lot about these tensioners, I've never had one fail so I've never had to work on one.
What I can say though is to keep an eye on the pulley bolted on the crankshaft. It will have a rubber layer in between the two metal parts. These can become separated and it'll be likely the rubber bit will find it's way onto your timing belt - like it did on my Xantia!
