Special Tool
Timmy69
Re: Special Tool
Unread post by Timmy69 »
Well if your in the Business of doing several cars a week , month or year then it is a bargain..I am sure i would buy it if i were doing the same :)
Timmy
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I have one of those sets linked to by CGAT, and probably am also a special tool.
Before that, I used a large screwdriver with both hands, across the slots, whilst holding the caliper with my prehensile tail.
CGATCX25GTITURBO
x 16
Re: Special Tool
Unread post by CGATCX25GTITURBO »
Timmy69 wrote:Well if your in the Business of doing several cars a week , month or year then it is a bargain..I am sure i would buy it if i were doing the same :)
Timmy
nah, as you get older you learn to stop foo king around with your time, saving the frustrating, slips cuts grazes, relationships, cursing and other car parts :)
Until you get and use one, you might not be convinced, Another example, I fitted new injector seals to my 1.6 HDI Picasso, Lighty said to me 'get the washer extrator and seat cutter' found them on amazon for 90 quid I think, the main steelers wanted 120 quid to ATTEMPT the job, plus other charges if it went wrong. I couldn't believe how well the job went, it took seconds to get the stuck washer out, instead of prating with bent wire etc, a quick clean of the seat with the cutter and it all went back together as it should; jobs a good 'n
Neil aka CGAT
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
CGATCX25GTITURBO
x 16
Re:
addo wrote:I have one of those sets linked to by CGAT, and probably am also a special tool.
I have that tee shirt :) and scars! Pyhsical and Mental!
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
