Hi typeAlpha. Sorry I missed your earlier question. I flashed mine first time no probs (sorry!) - I could take a pic of the Galetto cable and disc if that would help. To actually rid the DPF successfully I downloaded and used Ecusafe's dpf-OFF option. Agree with Richard in that the BSI on it's own doesn't seem to work to do this. In the past I've posted that I just used Ecusafe / Galetto and other have said that the BSI alteration is need as well (??). So good job you can access the BSI I 'spose!
ps mine's a 2002 '52 plate mk1 2.2.
2001 C5 2.2 diagnostic connector/cable?
Monkeyfeet
Re: 2001 C5 2.2 diagnostic connector/cable?
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
DickieG
- Monaco's youngest playboy
- x 38
From what I recall I believe you're correct, the friend who did this used the same method as you describe then brought the car to me for a Lexia session just to see if any faults had been logged post defap, AFAIK nothing had but I know that the defap worked perfectly well.Monkeyfeet wrote:In the past I've posted that I just used Ecusafe / Galetto and other have said that the BSI alteration is need as well (??). So good job you can access the BSI I 'spose!
Prior to carrying out the procedure above I spent many hours going through Lexia (genuine dealer one) but no matter what I tried nothing would permanently rid the car of faults relating to low Eolys/blocked particulate filter and so on.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
typeAlpha
Well I finally got to read my ECU using the MPPS I bought no problem, looks like my Galletto cable was indeed faulty!
Nathan at http://www.check-light-on.co.uk is now modding my file to remove the nasty DPF and give a remap for a small boost in power. Hopefully I'll update later how it goes, fingers crossed.
C5 2.2 HDi SX
Monkeyfeet
Would definitely be interested in any news on that front - esp the small boost in power bit. Could be a useful file, that one.
typeAlpha
Car flashed with new file, limp mode gone completely and now feels a lot more torquey, all anti pollution faults gone - all that remains is a fault relating to ESP/ABS but I'm going to try disconnecting the battery tomorrow to see if it clears it.
Does feel a good bit quicker but it's hard to tell how much of that is placebo because it's been in limp mode for so long lol, I do believe there is a genuine increase in power though.
C5 2.2 HDi SX
typeAlpha
Looks like I spoke to soon, started car this morning for work and antipollution fault is back and car won't go over 4000rpm. I don't get it, car ran brilliant last night
C5 2.2 HDi SX
mick66773
Hi Sorry to hear about your problems, I bought a Gellatto lead with a disc of software, only one program would work, this read my ECU and stored to my laptop, I am yet to workout how to modify.
The plug is the OBDII that plugs into the left (Black Port) when fully pressed home a red light will appear on the side of the plug. The Limp Mode seems to place your car into a gutless lump and will not rev passed 3k. Hope this helps a little.
Monkeyfeet
typeAlpha, you still have probs? Now the engine's breathing better it may highlight any vacuum errors (my current obsession I admit) - don't forget the turbo needs full vacuum / no leaks. Alarm should clear after a couple of starts and will only appear when booted though.
mick66773 what in the map are you planning to modify, if you don't mind me asking?
