C8 Ecu
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Yes. :shock:
Stekelly
Re: C8 Ecu
Unread post by Stekelly »
So far so good. Have the Lexia talking to the car properly again.
I'm trying to sort an issue thats been on it since we got it. It's showing a fault with the fuel filler cap earth connection so I had a look see and theres switch or sensor that runs to the neck of the filler. I've disconnected it and sure enough, one of the 2 wires right as it goes in to the block is corroded away to nothing. Its bonded in to the unit so cant be repaired. I had a look on Citroen service and it shows a cable tha comes from 2 sensore on the top of the fuel tank then goes to a connector. ~I'm assuming the part I have is from that connector up to the filler? The cable I've removed ran down with the neck of the filler and was connected to another cable at the chassis that then looks like it runs up on to the tank. I cant seem to find the section on citroen service that shows the part I have. Can anyone identify it?
the end that was at the neck of the filler has HAMLIN 59600-409 on the top and 0321802 on the side.
Cheers
Stekelly
Re: C8 Ecu
Found it :-) I was searching in the electrica section. It's part number 00001503s1. Says £40 ish so I'll be off to a dealer at some stage to see what I can do.
EDIT. Just came across a site called parts reunited. Anyone used them before? Seems to be kind of an ebay for parts suppliers.
Parts Reunited.
Reason: Linky no worky - fixed now.
