HDi Xantia NOT on death row.. shes fixed.....
- x 8391
Re: HDi Xantia on death row UNLESS shes fixed.....
What about the third piston actuator on the HP Pump Paul?
citroenxm
- Fallen Hero
- x 70
That's the plug on top of the pump isn't it? you know Jim .now you mention it i get the feeling last time i looked around that that was still not working or deactivating ....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- Monaco's youngest playboy
- x 38
According to the diagnostic manual that's shown as a minor fault so won't activate emergency/limp home mode.CitroJim wrote:What about the third piston actuator on the HP Pump Paul?
Under fuel high pressure monitoring 1320 (fault code 1112 = major fault causing the engine to stop) low pressure is shown as being down to fuel starvation so blocked filter, clogged pick-up mesh in the tank, vehicle out of fuel, and to check the return flow-excessive return flow due to faulty injector/s, faulty fuel pressure regulator due to being seized.
As mentioned earlier if you can get the specific code recorded it will help immensely as there are 43 fault codes plus countless other diagnosis suggestions if no fault code is recorded, 56 pages of A4 is too much for me to type out
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
- Fallen Hero
- x 70
Ah that would be good... start tonight you be finished by tomorrow night Richard..DickieG wrote:CitroJim wrote:
I shall.. once I get me replacment screen.. I shall have a look...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
cc101
Possible Turbo Boost Pressure Sensor, dark red in colour with 3 vacuum pipes on it if I remember rightly. If it's faulty it will read an abnormal turbo pressure reading, normally under heavy acceleration measured outside normal parameters for more than 2 seconds will cut the fuel flow and engage limp mode. On the 1.6 hdi it's located nowhere near the turbo at the rear bottom timing belt end of the engine, not sure of the location on the 2.0 hdi!
Just a suggestion, hope it helps!
Chris.
Chris.
Xantia 1.9 TD 1993 (sinker)
citroenxm
- Fallen Hero
- x 70
Cheers Chris.. but limp mode isn't activated she stops dead.. after shestarts again she still has full power... not limp home so i don't believe its an over boost sense .. its in another area...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Well... AT LAST! We have - well this evening so far - problem solved!
I finally managed to aquire another untouched HDi High pressure pump for my car!
Tonight I fitted it.. To recap, I could not go above 3k, or put my foot down more then half way or the engine would cut out dead and throw on the ECU light.
So, I made a special effort to fit the replacment pump.. which incidentally took my 1hr 10 mins to do.
Result? YES! I gave the car a good going down the dua carrage way, Full throttle, hard accelleration and NO Cutting out!
My conclusion.. These HDi engines are Not as complex as they appear to be what so ever!
Next problem, the steering UJ joint, which is SERIOUSLY siezed! Ive left it sooo long its like driving with No PAS now!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8391
Re: HDi Xantia NOT on death row.. shes fixed.....
Excellent news Paul
And valuable information too
