Hi Guys
Ive just done the dash bulbs on my td xantia there were about seven gone and also the clock was out so was the heater switch bulbs. I had to replace the heater switch anyway because someone had broken off the air circulation knob, anyway after removing the steering wheel and shrouds and replacing the bulbs my problem was getting the bottom shroud back on.
That bottom back screw was a real pain to get back on it wouldn't go back in. A couple of times it dropped inside the shroud after id put one of front screws in i finished up breaking the bottom shroud were it lips over that little metal piece where the screw goes through pulling on it trying to get the screw back out.
So it was down the scrappes to get a replacement shroud and a new heater switch what a game it was and the shrouds are akward i found but apart from that i found the job quite easy (but time consuming)
pete....................
Xantia Instrument Panel Removal.
pete@co.uk
frankielunn
pete@co.uk
