Problem on hard acceleration
xenton
Re: Problem on hard acceleration
Unread post by xenton »
After clearing and going for a drive causing the problem at low speed in a low gear and at higher speed in a higher gear, the only code is the P1288.
Mark D.
2001 C5 2.0 HPi exec.
xenton
oneday wrote:P1162 SIRIUS 81 - Exhaust gas recirculation. Coherence
P1291 Injector High side short to GND or VBATT - Bank 1
SIRIUS81 (EW10D)- Fuel pressure regulation fault. Output/Locking.
Fuel rail pressure. Low value received.2
P1288 Cylinder head temp sensor Out of self test range
SIRIUS81 (EW10D) - Fuel rail pressure. Low value received.1
mostly seem to be pointing to fuel rail pressure. looks like you need to look at live data on a run to try and find the cause of the fault.
Thanks very much for the help, how do I get to view the live data, and what should I be looking for?
Mark D.
oneday
Unread post by oneday »
cant remember how you get live data someone will be on to tell you soon nodoubt if no contact jim if you got it from easy diagnostics he will tell you. i would be looking for fuel pressure drops on the high and low pressure systems. if the low pressure pump is to low the high pressure pump will not have enough fuel to get the pressure. if that is how the hpi engine works.
306 1.4 LX MERIDIAN
xenton
Thank you kindly.
Mark D.
xenton
Right,
I have a lexia, if someone could guide me through how to get to the live data I need, I would be most grateful.
Mark D.
oneday
hi just been out to clear some faults on mine live data is in perameters
306 1.4 LX MERIDIAN
xenton
Ah, then the only fuel pressure listed and requested and actual fuel rail pressures, there's no high and low pressures shown. Can just see actual falling well short or requested, which doesn't really shed anymore light on the situation.
Mark D.
oneday
how many bars of pressure have you got when the engine cuts out
306 1.4 LX MERIDIAN
xenton
It's always around 6-7 bar when it fails.
Mark D.
xenton
It doesn't completely cut out just hesitates then goes into limp home mode.
Mark D.
oneday
thats very low what pressure do you get at lower revs
306 1.4 LX MERIDIAN
xenton
When idling at 800 rpm it's at 88 bar varying between 86-89 as I sit and watch it
Mark D.
xenton
I just reved it slowly upto 3500 and pressure was sitting around 100 bar, then suddenly dropped to 30 at 3392 rpm
Mark D.
oneday
sounds like fuel starvation to the high pressure pump. are the filters clean if so the tank pump may not be supplying enough fuel
306 1.4 LX MERIDIAN
xenton
Thank you very much for your help. I'll replace the fuel filter and see if that makes any difference prob won't be able to do it until next weekend now, as its dark by the time I finish work. Thanks very much for your help, I'll let you know as soon as the filters been changed.
Mark D.
