Xantia Slip Ring
DickieG
Monaco's youngest playboy
x 38
Re: Xantia Slip Ring
Unread post by DickieG »
My previous HDi 1999 'V' reg RP 8382 2000 model year still had the RP number near the O/S strut.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
As said, AROUND V... Im not 100% sure where my RP is on V, but certainly from W onwards the RP is on the door pillar sticker.
Unless like the one I look after, its an early car with a late plate on it!!
A very sad...
1994 XM 2.1 d auto
Dommo
x 20
Unread post by Dommo »
That picture is from a T reg Activa, so a very late one then by the sound of things
DickieG
x 38
Dommo wrote:That picture is from a T reg Activa, so a very late one then by the sound of things
So the RP sticker mystery takes a turn, as your Activa was built 129 days earlier than my previous HDi yet has the sticker on the door, looks like the estates (built separately by Heuliez) continued with painting the RP on the bulkhead much later than the saloons built by Citroen.
Xantia trivia point no 4352 :lol:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 1477
My Estate is reg Jan 01, RP is something starting 88 I think - and is still painted on the bulkhead...must chek the door sticker to see if there too. Must also get out more!!
The two letters often found on the end of the RP number indicate the build factory - and it seems that on some later cars (eg Xsara Picassos) the change over of certain components happened at different times in different factories! So you need the full RP including the factory code. Oh, and they have also started calling it DAM....
Six-cylinder
Unread post by Six-cylinder »
I have now contacted several breakers without any luck, A5 French Salvage has one but the RP of the car is 8388.
I have enquired for a new one but that’s £150.
Citroen
1974 Ami 8 Break
1986 Visa 17RD, 1984 Cabriolet, 1983 652cc Special, 1983 GT
2000 C15D Club
1983 LNA Inca
1996 ZX TD Estate
1983 CX 2400
1978 GS
1972 DS
1997 XM 2.0 16v
1992 BX GTi 8v
1996 Xantia Activa
1974 Peugeot 504 cabriolet
1963 404 Saloon
1983 Renault 4 GTL
x 1477
This one ought to be early enough....http://tinyurl.com/7lqlxl4
x 1477
Just checked on Service.citroen - yes £150 - that is daylight robbery!! However, I had a thought, and checked MK1s - these use the same part as yours (well after RP 6965, which is 26 Aug 1995) - so that should allow you to widen your search a lot!
Six-cylinder
RichardW wrote:This one ought to be early enough....http://tinyurl.com/7lqlxl4
This was the one RP7900, I went over this morning and collected the slip ring, I have compared it with our original and it looks right. The garage that has the car say it should be ready Monday morning for me.
Thanks to everyone who helped.
Kind regards
Citroen
1974 Ami 8 Break
2000 C15D Club
1983 LNA Inca
1996 ZX TD Estate
1983 CX 2400
1978 GS
1972 DS
1997 XM 2.0 16v
1992 BX GTi 8v
1996 Xantia Activa
1963 404 Saloon
1983 Renault 4 GTL
x 1477
Nice one Chris - I'm going to have the front fogs off that one I think, to replace the smashed ones from earlier in the winter when I had an argument with some black drain pipes on a dark road :evil:
Six-cylinder
The Xantia estate was complete and I was the first person to have any parts from it, from memory the fog lights were there.
Citroen
1974 Ami 8 Break
2000 C15D Club
1983 LNA Inca
1996 ZX TD Estate
1983 CX 2400
1978 GS
1972 DS
1997 XM 2.0 16v
1992 BX GTi 8v
1996 Xantia Activa
1963 404 Saloon
1983 Renault 4 GTL
red_dwarfers
x 58
Unread post by red_dwarfers »
Maybe I'm missing something here but if an S1 Xantia part is compatible with an S2, what happens about the horn as the S2 is on the wheel whereas the S1 is on the stalk?
Another useful nugget, Xsara and Xsara Picasso slip rings are near as dammit the same as late S1s. The only difference being the radio control wire dashboard side, which with a bit of patience can be swapped.
Kev
'19 C4 Cactus 130 Flair
