Xantia Estate - new key required
xmexclusive
Re: Xantia Estate - new key required
Unread post by xmexclusive »
Keycode is just Citroens method of listing the position and depth of the cuts on the keyblade.
If you have an existing key as a pattern then the keycode is not needed.
If you have no pattern key then the keycode number needs verifying as a change of locks might not have got altered on the Citroen record.
As I read it Birdman is advertising his own site.
If so I have no problem except that I think it should be declared a little more explicitly.
John
Xmexclusive
x 8457
Thanks for the explanation on keycodes John :)
xmexclusive wrote: Jim
John
Thanks John, missed that first time round... Doing something else at the time I read that post :oops:
