Fixing battery terminals - how to?
Xantidote
x 4
Re: Fixing battery terminals - how to?
Unread post by Xantidote »
Gregg1100 wrote:hacksaw about an 1/8th inch off one of the opening lugs
I had to file a couple of mm off the inside of one of the opening lugs on my previous BX. Problem is that the lead alloy that the original clamp's made of is quite soft, and presumably suffers creep over it's life, especially if overtightened. I'm careful not to overtighten nowadays
Martin
1995 Xantia TDLX (deceased :( )
x 94
Unread post by citronut »
Gregg1100 wrote:One could also remove the securing bolt on the clamp, hacksaw about an 1/8th inch off one of the opening lugs, refit securing bolt and presto, one tight clamp again
i just gently open the gap and file some of the matting surface away at both sides,
that is if the lead has not split were the bolt goes through,
regards malcolm
Gregg1100
x 5
Unread post by Gregg1100 »
File or hack- gets the same result :)
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
