Rattly Clutch
x 94
Re: Rattly Clutch
Unread post by citronut »
CitroJim wrote: New clutch on order. ECP are doing a good deal on Valeo ones at the moment...
are you sure its a genuine Valeo one Jim from that bunch [-o< :wink:
as i feel there the Tesco of the automotive trade, squeeze there supplier down to the lowest half pennie they possible can,
then end up selling sub stander crap :evil: :evil: :shock:
regards malcolm
Chris570
x 36
Re: Rattly Clutch
Unread post by Chris570 »
i have to agree with what they are saying here, it sounds release bearing and we all know they fail on release bearings..... luckily i have a stock of slave cylindars :)
I'll be glad to lend a hand Jim, if only to get practice for when mine goes, although i'm still low mileage at 189k
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
x 1489
Re: Rattly Clutch
My response would have been the same as Handyman's - although I've not seen or changed one. You well know the trials of the hydraulic failure best avoided! Interested to read up on your experiences with this one, as no doubt it will come one day (123k on mine so far and no rattles yet). I remember the Doc of BX fame changed one in a 2.1TD and reported it took 10 hours, and he would rather sand paper delicate parts of his anatomy than do another - which must make it pretty horrible :twisted:
Having tackled a similar one (C5 2.0 HDi with a 6 speed ML box), my tip would be ignore fighting with unclipping the gear change cables, and just unbolt the whole bracket off the back of the box - 3 off 13mm (IIRC :?: ) reached over the diff - takes a couple of minutes.
Xaccers
x 188
Re: Rattly Clutch
Unread post by Xaccers »
robert_e_smart wrote:Thats the spirit Xac, get stuck in and do it! I like that attitude.
Well someone needs to be their with enough body mass to undo the hub nuts and break the cat litter tray, it's tradition :)
DIY sphere tool
Chris570
x 36
Re: Rattly Clutch
Can I be the guy that makes wise cracks while watching?
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Xaccers
x 188
Re: Rattly Clutch
I'm pretty sure the BOL says we need one and you do it well ;)
All we need now is when, good weather, plenty of tea bags and caramel shortbread
DIY sphere tool
DickieG
Monaco's youngest playboy
x 33
Re: Rattly Clutch
Unread post by DickieG »
Just to calm down all the talk of the thrust bearing being about to fail any day soon my old HDi had a similar rattle for the 40k odd miles I had the car for and AFAIK its still going fine to this day.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1240
Re: Rattly Clutch
Unread post by Peter.N. »
I have had this exact problem on a couple of XMs, as soon as you touch the pedal or increase revs the rattle stops, on one of them I had just fitted a new release bearing! They both went on clattering so I just used to blip the throttle to stop it, the other one which had a recent clutch replacement, eventually stopped doing it.
x 8401
Re: Rattly Clutch
Xac wrote:Invite a friend to help and put the kettle on.
When do you want to do it?
Thanks Xac :-D :-D :-D
It'll have to wait a bit, I'm entering a busy period but as soon a s it quietens down a bit and the weather is OK, I'd be most grateful fort a spot of help...
x 94
Re: Rattly Clutch
only if you are supplying the chocy bicies and can make TEA :shock: :lol: :wink:
regards malcolm
Xaccers
x 188
Re: Rattly Clutch
Anytime Jim, although the weekend of the 7th April might be hard to get past Danielle ;)
DIY sphere tool
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Is that when it's due?
Xaccers
x 188
Re:
addo wrote:Is that when it's due?
I wish! No, no chance of the patter of tiny footsteps for a while, we're far too knackered!
The wedding is now the 7th and after having to move it twice so far we ain't doing it again!
DIY sphere tool
Duracell
Re: Rattly Clutch
Unread post by Duracell »
Jim - My HDi Exclusive has had exactly the same symptoms for at least the last 50,000 miles without any noticable deterioration - Its the original Citroen clutch which has now done 186,000 miles and at the moment still works perfectly. I wouldn't worry about it unless the noise bothers you
lexi
x 133
Re: Rattly Clutch
Unread post by lexi »
Drive it till it drops. You have other cars should this happen. Less money ,less work and less wear on your knees :-D
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
