because i'm curious....
old'uns
x 127
Unread post by old'uns »
'02 110 estate 225k, bought @ 30 months old with 85k
off top of head :
5th crank pulley, 2nd belt
F & R discs
rear swing arm bearings
rear calipers problem 'repaired'
1 centre box
1 rear box.....now blowing at front somewhere
alternator
battery
new rad..long story, in France something got lost in translation & turns out was next item
rad fan seized 4 yrs ago, not got round to replacing yet.
a few other small things
steering pump now sounding slightly 'squeaky'
still on original clutch as far as i'm aware, no mention in service history & i know i've not done it. gives the odd little squeak every now & again, no signs of slipping
average mpg around 44 with carrying ladders/trestles on roof probably 2/3 days per week & equivalent of a couple of passengers in work related boxes
DHallworth
x 171
Unread post by DHallworth »
Our Xantia HDi 110 Exclusive is still a baby compared with some of these!
107k on her.
Done a lot of work to it so hopefully we'll get a few more years service from her yet...
Rear Spheres
Accumulator Sphere
Rear Silencer on Exhaust
Front Discs & Pads
Track Rod End & Track Rod
4 Michelin Tyres
Crank Shaft Pulley
Aux Belt Tensioner
Aux Belt
Injector Washers & Spaces
Replacement Glow Plugs
Replacement Glow Plug Box
Replacement Igniton Switch
Fuel Filters
Air Filters
Oil Filters
Wishbone Bushes
Rear Engine Mount Rubber
Rear Window Regulator
Track Rod End (Other side)
8 Replacement Spheres
Timing Belt
Water Pump
(I've got a spreadsheet of all the work done to it so I can keep a record easily.)
On parts alone I've spent about £1300 in 2 years getting the car up to scratch. That includes a set of Michelin tyres, and both MOT's.
Gonna need another crank shaft pulley before long too as the Euro Car Parts one on it has covered everything in that lovely brown dust and I've lost the receipt!
It just sailed through it's MOT 3 weeks ago without so much as an advisory.
David.
'98 Xantia Activa V6 :-D
'13 Renault Zoe - Broken
'15 C4 BlueHDi Feel - For Sale
lexi
x 133
Unread post by lexi »
What's with the crank pulleys? It must be the diesel engine with with vibration and big torque that does them. 4cyl diesel aint a smooth engine in the scheme of things.
It does the DMF as well..........sooner rather than later.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Chris570
x 36
Unread post by Chris570 »
fortunately we don't have DMF's :)
my crank pulley is up for replacement and a genuine citroen part is only a few pounds more than the ECP one (probably about the same if you ask for a discount) so i'll certainly be using Citroen's finest
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
DHallworth
x 171
I get trade prices at Euro Car Parts so the crank pulley came down to around £40.
The Peugeot genuine one we fitted to a 306 a few months later was around £90.
Not going to bother with the cheaper ones ever again.
Lexi - there's a rubber part in the crank pulley and as it gets older the rubber perishes and the pulleys begin to knock horribly. If I can find a solid one I'd use that next time round.
David.
dieselnutjob
Unread post by dieselnutjob »
my 806 HDI has 208,000 miles
two DMFs and now on a solid flywheel
power steering pump
knocking injector at 120,000
split intercooler
new steering rack last year but I think only really needed a track rod end
alternator drive pulley
numerous school run dents
currently running very well
