xantia versus c5
citroenxm
- Fallen Hero
- x 70
Citroenmad
- x 110
I saw those, they were very good actually, I enjoyed watching those episodes.KevMayer wrote:What made me consider safety was an article on the Fifth Gear motoring programme.
They did some very graphic tests to demonstrate how much more 'survivable' a crash would be in a modern vehicle.
A friends dad went out and got her a Peugeot 106 for her first car, after he thought it was a bit flimsy and watched the 5th gear episode where they hit a tree with a Laguna he went out and bought her one of the early 5 star LagunaIIs with the smallest 1.6 engine instead.
The test between old and new Espace and the Modus vs Discovery was very very good.
A very informative car program, we should have more like it.
Cars move on in many ways, safety is one of the biggest factors about new cars.
Just slightly joining the Saxo thread here, I wonder how many people with lowered cars realise they have also lowered their crash protection beams and any car of normal height will just hit theirs at its softest point. Erm, none?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1240
Citroenmad
- x 110
Every PSA car of a similar year uses very similar electronics, that is Comms2000 or multiplexed cars.
Considering the amount of PSA cars on the roads with similar running gear and electrics to the C5, id say reports are not too bad. After all, most reviews are only placed when an owner is dissatisfied, not as often whent he like them as there is less to report.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1240
addo
- Sara Watson's Stalker
- x 95
I think it's folly to speak in absolutes.
Damn near every multiplexed PSA I plug the Lexia into, has BSI faults logged and also a radio aerial fault.
Recently worked on a C5 facelift estate that had a permanent power (signal?) supply fault on the steering angle sensor - hence suspension was set harder than it need be. I'd put this down to duff connectors somewhere between BSI, sensors and the H2+ ECU. At least the Xantias have analogue connections to track down in similar cases.
A low mileage country driven C5 that has been garaged, would be a good car. Ditto on a Xantia!
To my way of thinking, the increased use of resistive tracks on C5s (compared to Xantias) means more routine service items are "remove and replace" rather than "remove and clean". Height correctors and accelerator pots, for example. Hence my comments about prior duties of the car.
Taking the emotion out of car purchases is bloody hard - I have often used Excel to compare options, and the outcomes can sometimes surprise.
Cheers, Adam.
Cheers, Adam.
C.J.
I'm starting a bring back plugs points condensors carburetors and vacumn operated wipers campaignCitroenmad wrote:Every PSA car of a similar year uses very similar electronics, that is Comms2000 or multiplexed cars.
Colin
My cars:
1988 AX GT and still running sweet. Genuine 41 k only!!
2005 Skoda Fabia vRS 83k...and truly awesome.
Vauxhall Combo crew cab SE
Citroen Saxo 1.4 Furio.
Their cars:
Hyundai Getz.
Hyundai i20
Eriba Puck caravan now too!!
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
P616VKX
I'd never have a C5 because I found the HDi engines to be choking to drive... Genuinely took all of the excitement out of driving a car when I drove a C5, soft, soggy, droopy, lumbering piece of metal that I just couldn't get on with. Electronic height control is another thing I really detest.
The Xantia on the other hand has proven itself to me to be very nippy, fiery and reasonably taught (Not an activa). The ease of service is amazing, radiator grille off within 30 seconds now to access the fan relays, all bulbs and fuses readily available (Unlike the C5 where the front bumper has to be removed to replace headlight/sidelight bulbs), the brakes felt nicer in the Xantia too, much more reassuring... And of course, the Xantia is a Xantia... It's always going to look the part when polished...
The C5 makes a good taxi due to the space and economy, but for driving experience and fun, it has to be a Xantia every time. As said, mine isn't an Activa, but it has the rear-steer as every Xantia has, and that makes driving swiftly, very fun.
Xantia's are cheaper to run in the long run due to less things being there to break in my opinion. And I've yet to spend over £10 on it (Even with a full service, £8.04 minus the oil).
B564PLC - Red/Grey Renault 11 GTL 'Premiere'
Ozzie Kuma
I waited & waited to get the C5 till this year, ..the day came, walked in to the sales room, money in pocket & thought I'll ask for a test drive, just to be diligent & oh am I glad I did.
I was very disappointed.
One of the main points was when I put my foot on the break, the nose dived or more correctly the tail lifted, something that does not happen on the Citroens I have owned thanks to the pivotal rear suspension ( don't know the teck name for it) & something I consider a great safety point ... just personal opinion.
98 Xantia V6 MK2
95 Xantia VSX
98 Xantia V6 MK2
95 Xantia VSX
Citroenmad
- x 110
HDis are a nicer drive than the XUD, even if the XUD appears more robust the HDi is a more refined and easier car to drive thanks to its power band.P616VKX wrote:I'd never have a C5 because I found the HDi engines to be choking to drive... Genuinely took all of the excitement out of driving a car when I drove a C5, soft, soggy, droopy, lumbering piece of metal that I just couldn't get on with. Electronic height control is another thing I really detest.
You dislike the electronic height control? For what reason? Its more simple, its quicker and it does the same job
Of course the Xantia has brakes powered by the hydraulic suspension system and it does make the pedal rather sensitive. The C5 has conventional brakes but they actually work just as well is not better as they are much larger.
I can say you do not have to remove a C5s front bumper to get at the bulbs!
Ive not had any great concerns in the time we have ran C5s, they generally just go on without any hassle. Our C5 estate has done 25K in the 21 months we have had it, other than servicing and tyres it has not needed anything at all. Likewise my C5 has done 5K with me since I got it in Jan and ive not done a thing with it. My last one I had for just over a year, that needed a few bits and pieces doing but nothing costly and our current 110 HDi has been extremely reliable for the 22K miles its done with us. I can't fault them for reliability.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
citroenxm
- Fallen Hero
- x 70
If anything the hdi s are proofing more robust and stronger... there's certainley much less head problems then xud before they get to 200k which I like.... I think that's down to the standard fit laminated gasket... once these are fitted to xuds. The problem goes...
Love the hdi I'm a big fan...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
daviemck2006
- x 485
It really boils down to personal opinion. I've never driven a xantia so cant compare them but my c5 has been the most reliable and one of the cheapest cars to run I have ever had. True, it's not a sports car in the handling stakes, but that's not what its about. It's big, quiet, comfortable, refined, reliable cruiser, and I can change all the bulbs in minutes without removing anything and I hane big hands! A xantia may be a better drive, espically a petrol one if you like revs, but would be no use to me, being too small and light for towing. Different cars for different jobs and different people. I sometimes wonder if this furum should be called the xantia forum!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 1240
XantiaDaveEire
- x 4
AgreedPeter.N. wrote:We are all stuck in a time warp and don't like modern cars
But also the fact that modern Citroens don't really cut it in terms of what a "proper" Citroen is.The designs imo are far too safe and just not quirky or original.
The fact that the latest bog standard C5 has coil sprung suspension says it all really
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k
