Xantia Starter Bolts
addo
Sara Watson's Stalker
x 95
Unread post by addo »
New one may be a direct drive starter with field coils. Did it have big countersunk screws on the body of the starter?
x 94
Unread post by citronut »
i use a half innch drive ratchet with a short extention to overcome the one bolt above the clutch lever,
regards malcolm
ids987
Unread post by ids987 »
addo wrote:New one may be a direct drive starter with field coils. Did it have big countersunk screws on the body of the starter?
Hi Addo, Yes - I think so.
citronut wrote:i use a half innch drive ratchet with a short extention to overcome the one bolt above the clutch lever,
regards malcolm
Hi Malcolm, might be the length of the hex bit on mine. The body of the key driver was over the clutch lever.
