I am located in Stratford, but have just got hold of a Lexia off a friend.
I will run some diagnostics tonight, mother in-law permitting (she is visiting).
Turbo fails at 2900 revs, main d say it is ECU, Xantia
zoics99
Hi All, I have run the Lexia 3 over the system. The faults first highlighted -
Turbo Pressure electro valve Inlet pressure LOW - permanent fault. It appears that the pressure is 1365 milli bars, and is corrected to 2042 millibars. OCR at 88%. At 2731 revs the injection is 55mm cubed. This does not mean much to me.
I am new to the lexia and cleared the faults with a view to retest and the battery is now flat (car) so will retest tonight after a fresh run.
I love my Xantia!
zoics99
All,
The Lexia reported this error (after i cleared the errors and took the car on a fresh run).
permanent fault, Turbo Pressure Electrovalve measured inlet pressure too low
Engine speed 2923 rpm
Injection Flow 54 mm cubed/cp
Gross inlet pressure 1318 millibars
Corrected inlet pressure 2047 millibars
Turbo Valve OCR 88%
Any ideas where to start from here? I cannot see any splits in the pipework. Could it be the intercooler, and if so how can i test?
Many Thanks,
Matt
[/img]
Turbo Valve OCR 88%
Many Thanks,
Matt
[/img]
I love my Xantia!
cachaciero
- x 9
With respect you really need to understand what is going on here, I can't help because I don't even know what injection system is fitted and I don't have a Xant.zoics99 wrote:All,
Turbo Valve OCR 88%
Many Thanks,
Matt
[/img]
BUT I do see some contradictions here, the first is that I would not expect a low inlet pressure i.e underboosted to put the engine into LIMP mode, but I would expect an overboosted pressure to put it into LIMP mode, the second is that the rest of the data would suggest that the inlet pressure is in fact high.
So...! these re my mental questions what is the the "turbo Valve"? what does it do actually. How is turbo pressure controlled by a wastegate system or actuall control of turbine nozzle a'la C5
What pressure range does the system expect to see? what actually is gross pressure? and corrected pressure is corrected to what? is it a normalised value taking into account temperature?
Now this is my best guess
In summary I suspect that the waste gate valve is not blowing of excess pressure, the ECU is driving the control EV to do this but it is not happening. Ergo either the waste gate valve is stuck closed or it is not getting any vacuum to drive it. If no vacuum then check for split vac pipes or failed Electro valve.
Quick check pipe the waste gate vac control line directly to vac pump and go drive, you should have little turbo boost but no overboost and no limp mode if the waste gate is working properly.
Caveat I don't have and never have had a Xant I may be talking rubbish.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
zoics99
No respect needed. I am a novice on Citroens, and Diesels. But I love the Car.
It seems to lag power all the time. It was an almost instant change. The error and turbo light only come on under hard acceleration - when there is no power.
Thanks for all the help. I am still looking at it.
I love my Xantia!
