I did say similar tolexi wrote:Whenever the word Fluro comes up I smile. Many tests have been done on "flurocarbon" fishing line and basically they are a rip off in price and what they are supposed to be in the actual term fluro. Some tests said it was line with soap on it.![]()
Afaik there are no fluro silicones in a tube. I think they are manufacturer extruded into shape?
Rubbers are interesting![]()
Silicone sealant and LHM
HDI
- x 7
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
lexi
- x 133
Xaccers
- x 188
Malcolm's probably busylexi wrote:Two pages on silicone rubber and nobodys mentioned Breast Augmentation ?![]()
DIY sphere tool
DIY sphere tool
- x 1941
Not until you!!lexi wrote:Two pages on silicone rubber and nobodys mentioned Breast Augmentation ?![]()
Dommo
- x 20
Little update. I did get around to opening the tube of sealant I have, it does have the vinegar smell to it.
I dolloped some onto a surface, let it set slightly, then put it in a bottle cap with LHM in. Just went to have a look and the silicone looks in the same shape as before but the LHM does smell of vinegar, a bad sign?
Thanks.
Thanks.
lexi
- x 133
If you had let silicone cure before exposing to LMM the smell may not have been there and the silicone is then more stable. 48hrs depending on temp and thickness of bead.
Even two part Polysulphide takes 7 days to fully cure .
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Dommo
- x 20
