Im after a part
x 8415
KevMayer wrote:I called a Citroen dealer today and he quoted £403 incl vat for a rear ram part no. 509004.
Yep, that's it. £403. :evil:
Be prepared for a long wait though, mine's on back-order until the 22nd of the month.
I wonder if you could fix the balljoint from an otherwise scrap ram Kev?
KevMayer
Unread post by KevMayer »
It would be great if I could change the top ball joint on my rear ram.
What i've noticed is that I get a strange sensation from the back whenever I drive over a speed bump. It feels like the rear left wheel takes all the load and the rear right appears to sink slightly. Almost like I'm riding on 3 wheels. I assume that this is the 1/8" play in the ball joint coming into effect and the anti roll isn't taking effect straight away. Other than that I don't realy notice anything when driving or cornering.
I think the ball joint is removable from memory. So, one from a scrap ram would be good.
I'll haveto remove the ram and take a look. I've had the rear ram off once already and it was'nt much of a job to do.
Otherwise, I'll just save up the £403 because I think it's got to be worth it to sort it out. The alternative is unthinkable.
Cheers, Kev
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Is it possible you've a duff sphere at one of the rear corners? That will flog your antiroll linkages pretty hard.
KevMayer
Addo.... good point.
I'll get two new rear spheres fitted and see what happens.
Cheers, Kev
