Activa owners - what tyres are you on?
ACTIVE8
x 6
Unread post by ACTIVE8 »
anybloodybody wrote:'V' rated - good for 150mph
I thought the higher the rating, the softer the compound?
So why go for a 'W' rated?
Ask Citroen about the "W" rating, it's what they specified for the car, take a look at the O/S "A" post on your car, and you should see a tyre spec sticker.
"W" rated tyres are for a higher top speed, (when a 2.0CT eventually gets there :wink: ) but also have a stronger sidewall, which the Activa needs.
ACTIVA
Koukku
x 8
Unread post by Koukku »
I took my Activa to the track with the H rated Gislaved tyres, and competed only about 5 fast laps because they overheated and started to lose pieces of the tread. :lol:
- Previously Activated -
XantiaMan
x 18
Unread post by XantiaMan »
My Activa says V rated tyres...
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
Sl4yer
Unread post by Sl4yer »
I was quite surprised to find that Michelin don't even do a suitable Activa tyre anymore!
Shame, because the Pilot Sport 2 is excellent.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
anybloodybody
Unread post by anybloodybody »
My Activa says H rated Gislaved tyres
No lean machine
ACTIVE8
x 6
So it appears there are stickers with different specs on them.
ACTIVA
Peal
Unread post by Peal »
P7's here for the last 10 months. they do let go in a straight line due to the tread pattern.
I had a mix when I got it, with V patterns that seemed to be better in a straight line.
Alan
97 Activa CT
x 5672
anybloodybody wrote:My Activa says H rated Gislaved tyres
IIRC they are rebranded Firestones.
I used to pass the factory in Gislaved almost daily and remember Firestone taking it over.
Xaccers
x 188
Unread post by Xaccers »
Juliet's running on Ceats, which I have to say I'm impressed with.
Need new tyres on the fronts though, and also discovered they're all V rated even though sticker says W, so will put rears on the front, new W rated on the rear and next month probably have to replace the fronts :D
Quick question though, what load rating should they be?
DIY sphere tool
XantiaMan
x 18
Xac wrote:Juliet's running on Ceats, which I have to say I'm impressed with.
The Activa was designed for W's so if you can find them , fit them as they are better for it. Mine has been fine with V's on the front and the choice is much wider, i've been very happy with the Goodyear Hydragrips.
2017 Fiesta ST
Xaccers
x 188
That's the plan, Kwik Fit (yes, I know) have W rated P7's for just under £84 online price fitted.
I take it 91 is enough load wise?
DIY sphere tool
KP
x 27
Unread post by KP »
http://www2.yokohama-online.com/gb/tyre ... yreID=1011
Thats what i have Xac in the 95 load rating.
its good in the dry but in the wet its not so good and snow is pretty poo.
next time i get a set of front tyres which should be in a few months, i'll be looking for something that has very good wet grip...
