Synergie non start!!
x 8391
bxman wrote: Two Questions 1.
Is this circuit diagram xu7jp4injcct in the link above the one with the Magnetti Marelli 8P ecu. ?
And a very happy New Year to you and yours Patrick :D
I'll have a check in a bit. I *think* it's the MM one but need to confirm. been out all day and not long got home...
prosweencarcare
Unread post by prosweencarcare »
hi, definately not timing issue, just to clear that up.
Sorry might be me being thick but couldnt see a link to wiring diagram, could you post it again please?
is it supposed to be one i can cut and paste in the address bar? as there is nothing i can click on, cheers Jon
AndersDK
Unread post by AndersDK »
How about checking the battery pole voltage ?
If the battery is low on charge, all kinds of weirdoes may start singing their tunes once ignition is tuned on.
Try if a normal start can be obtained jump starting it.
Anders (DK) - '90 BX16Image
x 5674
prosweencarcare wrote:hi, definately not timing issue, just to clear that up.
Link works fine, prosweencarcare.
Here it is again, just in case: Diagram. (tested)
Which browser are you using?
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi Jon
If you look at Jims post you will see the link is in blue letters just point the cursor over it and click
Colin
x 8391
My apoloogies. The "Example Circuit" I posted was not for the MM8P.
This one IS though...
Typical MM8P Injection Circuit
prosweencarcare
ok, been away for a bit
about to go and check ecu earths and stuff like that, can anyone give me a list for the wiring diagram so i know what each componant is please? Cheers guys Jon
