Xantia Estate Rear Suspension Arm Bush Kit
Mandrake
x 694
Unread post by Mandrake »
ellevie wrote:
Mandrake wrote:Can someone tell me the approximate size/weight of a bearing/seal kit ? (For a hatchback)
SKF VKDA 23001 Rear Arm Bering Kit for BX
Bolt/Nut/Washer.....427g
Spacer ...................275g
Bearings x2............150g
Thrust Bushes x2.....80g
Seals x2...................25g
Dust Cover...............20g
Box ........................115g
Total......................1092g
box dimensions.....330x75x105 mm
The bolt, spacer, thrust bushes and possibly the dust cover should be reusable.
GSF and others do the bearings and seals separately.
Regards,
David
Thanks!
I know the bearings are the same between the BX and Xantia, but are all the other bits like the thrust bushes, seals, dust covers etc also the same ?
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
AndersDK
Unread post by AndersDK »
Regards,
Simon
Yes. Exactly, precisely and 100% accurately the same bits.
Anders (DK) - '90 BX16Image
Mandrake
x 694
AndersDK wrote:
Regards,
Simon
Great.
Here in NZ I'm probably better off getting the bearing kit directly through SKF, so I'll try the above part number at a local SKF supplier and see if they have it listed... :)
Regards,
Simon
Simon
1978 CX 2400
