Thanks!ellevie wrote:SKF VKDA 23001 Rear Arm Bering Kit for BXMandrake wrote:Can someone tell me the approximate size/weight of a bearing/seal kit ? (For a hatchback)
Bolt/Nut/Washer.....427g
Spacer ...................275g
Bearings x2............150g
Thrust Bushes x2.....80g
Seals x2...................25g
Dust Cover...............20g
Box ........................115g
Total......................1092g
box dimensions.....330x75x105 mm
The bolt, spacer, thrust bushes and possibly the dust cover should be reusable.
GSF and others do the bearings and seals separately.
Regards,
David
I know the bearings are the same between the BX and Xantia, but are all the other bits like the thrust bushes, seals, dust covers etc also the same ?
Regards,
